Project Configurator export settings question
kdickason
July 26, 2022 edited
We are attempting to export a project using Project Configurator.  On the Export Projects screen there is an option to specify the Projects to export and a checkbox for Select All Projects.  Which option is used if you specify a project AND check the checkbox for Select All projects?  Do I get just the project I specified or all projects?
Radek Dostál
July 26, 2022
The better question is why don't you just choose the option you want?
kdickason
July 27, 2022 edited
A third party is doing the export for us.  They have handed us a 22GB file for a project that is relatively small and has under 100MB of attachments.  They are insisting that although the checkbox was selected, because they indicated the project name, the export only includes data for that project.  Before we attempt to load a 22GB file, we are trying to understand why it may be so large and whether these two options, used together, gives us all projects, not just the one we requested.
Like Katherine Beckman likes this
