Jira Version 7.5.0 Server
I tried to import a Project from one to another Instance. Both Server, both Version 7.5.0
Error Massage:
This data appears to be from an older version of JIRA. Please upgrade the data and try again. The current version of JIRA is at build number '75005', but the supplied backup file was for build number '73010'.
75005 releated to 7.5.0, 73010 doesnt exist: https://confluence.atlassian.com/jirakb/jira-build-and-version-numbers-reference-347341143.html
Next Step:
Export an Project from the "Target" Project, delete these Project and import the Project to the same Instance (from his own Backup!).
Same error!
I also tried the Addon Project Configurator. Same Error Message.
I Need Help! Please ;-)
I have the same issue.
Both Jira instances are:
but I have the following error when trying to import:
This data appears to be from an older version of JIRA. Please upgrade the data and try again. The current version of JIRA is at build number '71014', but the supplied backup file was for build number '71006'.
Hi Stephan!
SELECT * FROM upgradeversionhistory;
Best Regards.
Hi Henrique,
thx for the answer!
1. we didnt migrate this instance from cloud, every time this was an server installation
2. the result:
"ID" "TIMEPERFORMED" "TARGETBUILD" "TARGETVERSION"
10530 20.06.14 6163 6.1.7
10330 04.01.13 845 5.2.4
10430 24.04.13 853 5.2.10
10230 06.08.12 772 5.1.1
10000 24.09.10 531 4.1.2
10010 03.12.10 587 4.2
10020 06.12.10 588 4.2.1-b588
10030 13.04.11 616 4.3.2
10130 30.12.11 664 4.4.4
10630 04.09.15 64026 6.4.11
10730 26.08.16 71013 7.1.9
best regards
Stephan
Help us plant more trees
