Project access Privat
Dejf November 16, 2024 edited
some docs pages states that setting a team managed Jira project to Private Access is not available in the free plan.
Nevertheless I managed to create one. Not sure how this was possible but now when trying to create again an access restricted "Private" project, it is not possible anymore.
Here the screenshot of the "Private" one in the free plan
Can it be that "one" (1) project can be be made "Private" but not a second one?
And indeed, I created a new Jira Account and for the first Jira Project I see the option:
Thanks and regards
Dejf
Trudy Claspill
Hello @Dejf
The only time the Team Managed project Access setting can be changed is if you are using a paid subscription or using a trial of a paid subscription.
If you had upgraded your Free instance to a Trial of the Standard plan, you would've been able to change the setting then. And the setting would be retained when you reverted back to the Free plan.
If you need to change it again, you will need to upgrade to a Trial of the Standard subscription, then change the Access setting, then revert back to the Free plan.
FREE
atlassian, confluence, loom, atlassian intelligence, ai notes, ai-powered meeting notes, atlassian community events, ace, confluence ai, loom ai integration, ai note-taking, atlassian ai features, team '25, atlassian live learning, confluence automation
Unlock AI-powered meeting notes: Join our live learning session! 📹
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!
