Project and bitbucket repository not found
Fabio Mamonjy October 11, 2025
I could not access my jira projet and its bitbucket repositories anymore. Anyone could tell me what to do to restore it?
Regards.
Daria Kulikova_GitProtect_io
Hi @Fabio Mamonjy and welcome to the Atlassian Community!
Were your repositories deleted because of inactivity? Recently, there were a lot of comments about it. As @Gor Greyan said, it's better to raise a ticket for support; maybe Atlassian Support will be able to help you: https://support.atlassian.com/contact/
In any case, it's always better to have a backup of your Jira and Bitbucket data. Having a backup copy, you always have the possibility to restore your important Jira and Bitbucket data. It can be built-in Atlassian options - import/export possibilities for Jira and Bitbucket, - or third-party tools, GitProtect for Jira and Bitbucket.
Thank you for your response @Daria Kulikova_GitProtect_io
Fabio Mamonjy October 12, 2025
@Daria Kulikova_GitProtect_io I think my project was deleted because of inactivity. I do not have any backup. I try to contact support but i did not find any process to restore it. Do you have any idea, please?
Gor Greyan
October 11, 2025
Hi @Fabio Mamonjy
It sounds like you might’ve lost access due to a permission or workspace change. A few things you can try:
  • Make sure you’re logged in with the right Atlassian account (especially if your company uses SSO).
  • Check with your Jira or Bitbucket admin — they can confirm if your access or role changed.
  • If the project or repos were moved or deleted, the admin can also restore or share the new links.
  • Try logging out and back in, or clearing your browser cache — sometimes it’s just a session issue.
If none of that helps, reach out to Atlassian support and share your project/repo URLs — they’ll be able to check on the backend.
