Project issues migrated using Back to Copy product data not on destination
marafado88 September 13, 2024
Hello everyone,
Have copy a project with 20 issues, and all seems fine from copy feature, but on destination there's nothing.
Did here a test with other projects and can see all the issues on destination but for this one, nothing.
Am I missing here something?
On source:
On destination:
Migration status:
Walter Buggenhout
Hi @marafado88,
It's not quite clear from your screenshots if the project ended up on the destination site and you can't see any issues or if the project itself was not copied over.
If the project is there, check if you have access to the project (browse project permission). If you don't, you won't see any issues - even if they are there.
Hope this helps!
This project was at least created on destination, but there's no issues in it, even seeing that status on migration about 20 issues (that makes sense compared with source tenant):Screenshot_674.png Screenshot_673.png
Walter Buggenhout
It is not because you're in the Administrator role that you have browse project permission in a project.
If the migration tool shows that all data was transferred correctly, it is most likely there. You should check the permissions tab under project settings and make sure that the Administrator role is indeed linked to the browse project permission.
Ah ok, after adding administrators group into browse projects, I was finally able to see. thank you a lot Walter!
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
