Project notification is disabled, but I receive notifications for commented issue if I am mentioned
Omid H_ December 4, 2020
I experienced the following problem:
If I disable the notification scheme for a project, I will be notified if someone mention me in a comment field.
Do you have the same bug?
Br,
Omid
Clark Everson
@mentions are separate.  As long as a user has view access to an issue, if they are @mentioned they will be notified as the message is set to direct to them. It's not a bug but there are other posts on this matter.
Depending on the add-ons you have you maybe able to disable them
https://community.atlassian.com/t5/Jira-questions/How-to-disable-email-notifications-for-mentions-in-comments/qaq-p/734642
