I want to create a project picker field but I know the original field Jira provides does not allow restricting the options. Like if I change the create issue permission on a project and don't want people to create an issue to that project I want to be able to disable that option.
So I created a select list field, wrote an automation to update the options if I create a project the automation adds the project to options.
But if I change the permission it does not disables the options. Is there a way to do that?
Disable options according to the permission update?
Thank you.
Welcome to Community :)
Presently, there is no direct way to do this.
Please check if this helps you : https://support.atlassian.com/jira/kb/how-to-restrict-field-editing-to-specific-users-in-jira-cloud/
Thank You,
Prachi
Unfourtunitly this does not answer my question. My question is not about restricting the editing.
Thank you!
