×Hi,
i am working through some Jira Automation rules and I’m looking to prompt worklogs to be requested upon the transition of a status into Done.
i have it as comment but is there a way to force the worklogs box to open when moving a card into ststus of done?
Hello, Good day. You can add a screen (with worklog)field to the closed status transition. https://confluence.atlassian.com/jirakb/map-a-screen-to-a-workflow-transition-in-jira-company-managed-projects-720634253.html
Hi @dexter driver ,
And if an entry is required, you can also define a validator from Atlassian or a workflow app (such as our Jira Workflow Toolbox) in the workflow configuration, which marks the field as mandatory.
Cheers
Frank
