Hi, I am a newbie here.
I already have a customized ProseMirror in my project.
How can I parse the format to the ADF format so that it can be used in the Jira cloud?
I already find the @atlaskit/adf-schema and @atlaskit/adf-utils but doesn't have any document or source code to help me use this.
Thank you so much.
Don't have the answer but have you looked at: https://atlaskit.atlassian.com/packages/editor/editor-json-transformer
