Hi All
I'm trying to query something that I believe should be very simple: "Find stories CURRENTLY assigned to a sprint" or in other words, ignore the backlog.
I tried using this JQL: "issuetype = Story and sprint is not empty".
However, I noticed that a specific issue ABC-123 is not returned in the results even though it's currently showing like this in the UI "Sprint: None [+1]"
So what I understand is that, even though ABC-123 has currently a none sprint, the fact that it was assigned in the past in a sprint and taken out to backlog, it still comes back in the query...
How can fully ignore the backlog?
Thank you in advance.
The sprint field is not as simple as just "current sprint", it needs to contain all the sprints an issue has been through, so that you can report on old and current sprints (but not the sprints that have not been started)
You need to use the functions to do this. Try
sprint in openSprints()
There are two others you might find useful in the future - futureSprints() and closedSprints()
Thanks Nic for the answer.
I'll be trying that.
It's just so mind boggling how a very basic need is not answered in a simple query.
I looked also for a way to find that backlog. Apparently there's a need for a complex JQL there as well. Such a complex JQL for such a basic query in Agile processes...
If you're from Adaptavist, I hope you will come with some functions to make this easier 😉
Thanks again
The thing here is that your board automatically provides that basic need, it's what boards are for.
The best Adpatavist could do is duplicate the function for "sprint in openSprints()"
Yes, the easiest way is to use the REST API to execute a search for "sprint in openSprints()"
