Hello community,
is there any DB query how to pull all used gadgets on all dashboards ? We need to find where and which native/3rd party dashboard gadgets are used.
You could probably build something from this (postgres):
SELECT pp.pagename, pc.gadget_xml, count(pc.gadget_xml) FROM portalpage pp JOIN portletconfiguration pc ON pp.id = pc.portalpage WHERE pc.gadget_xml NOT LIKE '%pyxis.greenhopper%' GROUP BY pp.pagename, pc.gadget_xml;
where:
portalpage = dashboard
portletconfiguration = dashboard gadget
I also chose to use WHERE pc.gadget_xml NOT LIKE '%term%' because I wanted to filter out any out of box gadgets, e.g. jira agile (greenhopper), or any com.atlassian.blabla things, because without the exclusion you will probably just get a ton of native gadgets but nothing 3rd party on first sight. So I think if you take some time to exclude those you're not interested in, you should then get a decent overview of which dashboards which gadgets are used on.
Thank you Radek,
this is exactly what I was looking for.
Best,
Matej
Hi @Matej Štrba
Maybe use REST API for this: https://developer.atlassian.com/server/jira/platform/dashboard-item-module/
Let me know if that helps.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
