Query syntax to search projects starting with "abc"
Coco S Chaussée
I created a project structure in jira with a specific prefix -say ABC- so i can query on that prefix.
How should the query be written?
July 18, 2019
Hi @Coco S Chaussée
Thomas is correct that there is nothing in Jira out-of-the-box...  If you have the ScriptRunner add-on, there is a function named projectMatch that would work.
Best regards,
Coco S Chaussée
Thanks @Bill Sheboy
It does work in ScriptRunner, but i would like the result of the query to display in Confluence.  How can i do that?
Coco S Chaussée
Never mind.  I figured it out.  I just had to save the query as a filter.
Like Bill Sheboy likes this
Thomas Schlegel
July 18, 2019
Hi @Coco S Chaussée ,
you can't query a project's name with a prefix. Never heard of something like this.
You can create a project category ABC and add all your ABC-Projects to that category. Then you can query "category = ABC".
