Querying Jira from Excel: error "We couldn't authenticate with the credentials provided."
Gauthier de Spa
I'm trying to import Jira tickets from https://<my company>.atlassian.net in Excel 2016 with a query, but with Basic authentication I have the following error:
We couldn't authenticate with the credentials provided. Please try again.
I've also tried to authenticate with a token in Web API authentication and have the following error:
A web API key can only be specified when a web API key name is provided.
Any idea on how to import my tickets in Excel 2016?
Note: I have no problem downloading the list of tickets from https://<my company>.atlassian.net/sr/jira.issueviews:searchrequest-csv-current-fields/10061/SearchRequest-10061.csv, but I need a dynamic solution.
Gauthier
Krister Broman _Advania_
September 24, 2019
Not sure about excel import but Web API certainly sounds the same as the REST authentication. For REST you need an API token to access the API so i would bet on that being the case for the excel import as well.
Follow this guide to create your api token: https://confluence.atlassian.com/cloud/api-tokens-938839638.html
In Rest you only provide one string for authentication encoded as base64 in this format
FORMAT: ”Basic ”+Base64 encoded string of "login name:API-key"
Exampel BASE64 (https://www.base64encode.org/): krister.broman:ABCDE12345 gives a3Jpc3Rlci5icm9tYW46QUJDREUxMjM0NQ
Final result for authentication: Basic a3Jpc3Rlci5icm9tYW46QUJDREUxMjM0NQ
