Question about ScriptRunner Script Field - Currently Struggling
MAG-II
Hello -
In my Jira project I am attempting to configure a Script Field that involves some basic math. There are 2 custom fields that are involved: "Amount Requested" and "Amount Returned." The Script Field is called "Amount Available."
What I want to happen is for the Script Field (Amount Available) to continuously calculate:
(Amount Returned) - (Amount Requested) = Available Amount
I currently have this script:
def aval = getCustomFieldValue("Amount Requested")
def bval = getCustomFieldValue("Amount Returned")
return bval - aval
So far it seems like this script is calculating the correct math. There is one step that I want to add to take this further though. Is there a way for me to set the Amount Available field to 1000, and then continue with the scripted equation?
In short, what I am ultimately attempting to achieve is:
1000 + (Amount Returned) - (Amount Requested) = Available Amount
I am at a loss as to what I can do here (if anything). Would appreciate any help I can get. Thanks.
robert Mugabuhamye
August 29, 2019
hello Michael.
why not use another variable ?
def initialvalue = 1000
then at the end return initialvalue +bval -aval
Josh_Kochelek__Modus_Create
August 29, 2019
Agreed. If it's a static value then you should just addit to the equation.
Unless I'm missing something...
MAG-II
I apologize for bringing this up again, but I am running into a new problem. The following is the script I have so far:
def aval = getCustomFieldValue("Amount Requested") as Double
def bval = getCustomFieldValue("Amount Returned") as Double
// check both fields contain valid numeric values and if not set them to 0
if (aval == null) {
aval = 0
if (bval == null) {
bval = 0
if (aval != null && bval != null){
return 1000 - aval + bval
} else {
// return to some code to indicate a null value in one of the fields
return 0
With 1 Issue uploaded the equation works great, however, as I upload more Issues a problem occurs. Each Issue I upload adds 1000 more to the Amount Available field.
Quick example: The first Issue I uploaded with the Amount Requested = 100 and Amount Returned = 10 gave me Amount Available = 910.
I uploaded the second Issue and the Amount Available immediately went up to 1910.
Would there be any way possible to have this 1000 in Amount Available only occur 1 time, and remain static for additional Issues that get uploaded?
August 30, 2019
@MAG-II  - I'd try this:
if (aval == null) {
aval = 0
if (bval == null) {
bval = 1000
return bval - aval
} else {
return 0
MAG-II
Ah right I was doing that, but it did not appear to be adding up. After a long time of testing / trying to figure out what the problem was I realized that there was some kind of caching issue. It is working now. Thank you for you help.
