Question regarding reports on dashboard
Davor March 20, 2021
Is there a possibility to create this kind of report on JIRA dashboard?
image.png to
5 votes
Gorka Puente _Appfire_
March 21, 2021 edited
Hi @Davor Sedlan
Out of the box, you cannot created a stacked bar chart with the created issues by status. However, you could use the Recently created gadget and the Pie Chart gadget with the same JQL e.g., project = "Teams In Space" AND created >= -4w
In the recently created chart you'll see the created issues during the last 4 weeks, and split by resolved (green stack) and unresolved (red stack). Then, the Pie Chart gadget will display the created issues during the last 4 weeks grouped by status.
If you really need that type of chart, you need a third party app. We develop an app called Dashboard Hub for Jira, which provides more than 60 out of the box gadgets, and allow you to create your own custom charts if you need something more advanced:
I created a public link to share a dashboard with you, so you can see it live here.
Hope this helps!
3 votes
Tom Harris - Old Street
March 21, 2021
Hi @Davor Sedlan ,
While it isn't possible to create this dashboard with the built-in Jira reports this was one of the use cases we had in mind when creating Custom Charts for Jira.
With this add-on, you can create a wide range of chart types, including stacked bar charts, directly on your Jira dashboard.
Here's an example from your question:
You can try the app right now for yourself on our interactive app playground: https://www.oldstreetsolutions.com/jira-reporting-playground
I hope that helps with your question ðŸ™‚
Tom - Custom Charts Team
Davor Sedlan
Thank you for your answers
You're welcome!
