Questions about roadmaps and next Gen Jira
Stu
I have a significantly customised install of Jira in the cloud.  with many custom fields etc. and several Kanbans.
I really like some of the new features in next Gen Jira.  Is it possible to recreate what I have in Next Gen?  It looks like everything is very basic, and not a lot of ability to customize?
Alexey Matveev
October 24, 2018
You can not use custom field, workflows, field configurations, permissions schemes and so on, which you created for classic projects. Next-gen projects do not have the same features as classic project.
Stu
Thanks @Alexey Matveev can you suggest how I could get the Roadmap feature for my classic project in Jira Cloud.  I'm keen to be able to convert my Epics into a Roadmap view that displays a schedule etc.  Thanks
Alexey Matveev
October 24, 2018
It is not possible right now. Maybe it will be available in one of the future releases.
Carlos Guardado
November 7, 2018
I'm trying to re-create a roadmap in the new gen jira but can't go back for a previous date. I believe it's the same issue expressed by Stu. There is only a "Today" option and no drop-down, do you know if this feature will be available soon ? or if only new projects can be done ?
Thank You
