My use-case is, as a JIRA user I want to bulk create a subtask within multiple stories.
i.e. I have 60 stories across a few different epics ... I want to add a "QA Effort" subtask to all of them in one fell swoop.
Is that possible with this plug-in
Only if you used a workflow transition and the plugin's workflow post-processing function.
