REST API - Retrieving custom fields for an specific issue type for a particular project
krnsda04
April 24, 2024
This is the API URL I am using to get custom fields of a specific project. It give me custom fields after i filter out the API response a bit.
But my requirement is to get custom fields for each issue type in that project. Like if i have Epic and story ,I want custom fields of them both individually. Is it possible , is there any API available for that?
I went though the docs couldn't find any.
url = f"{jira_instance_url}/rest/api/3/field?jql=project={projectID}"
3 votes
Sebastian KrzewiƄski
Hi @krnsda04
I'm afraid that in Cloud this is not possible to achieve. I couldn't find anything useful.
To confirm that you can ask Atlassian support.
Seba
krnsda04
April 25, 2024
Hi @Sebastian KrzewiƄski
Thanks for the quick response.
Sorry to ask this twice, but what does "I'm afraid that in Cloud this is not possible to achieve." means. In any other way is it possible other than cloud?
By saying that I was mean that on data center versions there is a rest api to get this info.
Faith Ntundi September 18, 2024
Are you aware of what that endpoint is @Sebastian KrzewiƄski ?
