ROVO Asset Agent
Davide Cascapera
Hi Team,
I would like to create a ROVO Agent to manage the asset, In charge of compiling asset attributes or creating objects according to incoming requests from projects.
Do you have any use cases or examples?
Thanks in advance
Best Regards
Aaron Geister _Trundl_
@Davide Cascapera
Good day,
I have not yet seen an agent that is able or as ability to managed assets.
This is a great use case though and very interesting topic. Could Rovo be a asset manager? I believe you would have to build a Rovo agent with Asset API capabilities using Forge and this might be possible. So there are Forge templates for Rovo and there is an extensive list of asset API's that could make this possible.
I hope this helps and maybe soon there will be marketplace Rovo agent available for this.
Davide Cascapera
Hi @Aaron Geister _Trundl_
Thanks for your help, at this point I think I'm going to start playing with Forge a little bit to see if we can build an agent that can manage the asset.
I will come back here when I will have something ready jsut to share my results
Best Regards
Davide
Like Aaron Geister _Trundl_ likes this
@Davide Cascapera
Good luck as I have found Forge to be so amazing and to make internal apps for my own team. Its pretty neat we can build our own solutions.
I did look at the market place and didn't find any Rovo agent dedicated to asset management so you might be the first to make it.
Have fun.
Like Davide Cascapera likes this
Davide Cascapera
will be cool to be the first one!!
Me and my Team  will start work on it from today!i will update you when we have something ready !
thanks for the support
Rimantas Andrulevičius
Also interested!
