Re-installing Jira Plugins, will data associated plugin be retained?
Ricky Lam
July 22, 2024
Hey there, due to some billings, I may need to uninstall and reinstall some plugins. I am worried that doing this will lose data/configuration tied to those installation and impact the development teams.
Does anyone know if data/configuration will be retained for uninstall/reinstall of plugins? I am looking specifically at
- Xray
- Release Management
- Structure
- Tempo
Francisco Fonseca (Xray)
July 29, 2024
Hi @Ricky Lam ,
Welcome to the Community.
For Xray, data stays stored for 60 days. Hope to have helped.
Best, Francisco.
Ravina
Hi @Ricky Lam This depends on the plugins. As some plugins have clean up tasks to remove the plugins data associated with it, but now a days most of the plugins does not delete the plugin data after uninstalling the plugins and data will be available once the plugin is re-installed.
If you have a Standbox instance you can try uninstalling the plugin and verify if the data is available or not.
Yuri Kudin _Release Management_
Hi, @Ricky Lam; I am a part of the Release Management team, so I can confirm that the data will be retained.
Yuri
