  • Community
  • Products
  • Jira
  • Questions
  • Re-open sub-task opens parent issue with post function but shows status as Open, Resolution Complete. How can I change this?
Davina Tsosie January 23, 2017
Greetings,
I was successful getting the post function to re-open sub-task to also re-open the parent issue. However, the status shows Open with Resolution Complete. How can I change this? This may also be the reason these newly reopened items are not showing up under Open issues. They show up under the kanban board but not the issues menu under reports and above components.
image2017-1-23 21:59:26.png
Your help is much appreciated.
Davina
Vasiliy Zverev
January 23, 2017
I assume that you make some transition for parent issue. In this case add a build-in postfunction for parent issue transition to clear resolution.
Davina Tsosie January 24, 2017
I got it working. Thanks
