How can I set some fields as read-only for my developers. I want that only project Administrators could have permisssions to edit that fields
I think you should consider this plugin http://quisapps.com/products/jfs
This was asked yesterday, and there's a good answer there - quisapps plugin mentioned, but also the "no plugins" workaround.
See https://answers.atlassian.com/questions/288838/restricted-edit-access-to-custom-fields-in-jira
I use on demandd version. How can i use this plugin?
Then you are out of luck.
You can read more here : https://jira.atlassian.com/browse/JRA-1330
