Receiving null response using the localhost
Sipan Hoj
March 29, 2023 edited
Hello everyone,
When I sent an IQL query to JIRA insight using an endpoint on the localhost I get a null response, but when I use postman to send the same IQL query that is generated by the same endpoint I receive the appropriate response.
It works well on my colleague's PC on the same branch using the same credentials.
In short I can not get the response through my localhost.
My PC can access the required destination and can get the data using Postman, but my localhost can not.
The localhost of my colleague works well, and this is what I get:
jira/client - error is not nil: Get \"https://jira.XXXX.com/rest/insight/1.0/iql/objects?iql_query\": dial tcp: lookup jira.swisscom.com on XXX.XXX.XXX.XXX:XX: read udp XXX.XXX.XXX.XXX
Any ideas, or maybe configurations needed.?
