Recommended Number of Active Workflows
Jessa July 13, 2017
How many workflows are too many that may compromise the performance in the future? Is there a recommended number of workflows?
Gaston Valente
July 14, 2017
Jessa,
I think it depens, it's not lineal, each workflow has a different weight in the total load it creates depending on:
  1. number of issue affected by the workflow
  2. number of conditions, validations and post functions and the complexity of each one
  3. number of services and listeners it has associated
But, for a rule-of-thumb you can use atlassian sizing guide:
https://confluence.atlassian.com/enterprise/jira-sizing-guide-461504623.html
From my point of view, having a large number of workflows creates problems with the administration first.
Nic Brough -Adaptavist-
July 14, 2017
A workflow only really imposes load when it is being used, not just because it's in the system.  There are far more important things, like complex and multiple permission schemes, active users, number of issues, complexity of fields on issues and so-on.
I completely agree with Gaston - your admins will be overwhelmed by too many workflows to look after before you'll be able to say "too many are causing a load"
Jessa July 21, 2017
Thank you! Your inputs are very much helpful
Register today
