In the JIRA Service desk, I could create reports by going to the JIRA Project, then Reports and New Report. Then I name the report and add some series. After doing this, there will be records saved in the "jiraschema.AO_54307E_Series" and "jiraschema.AO_54307E_Report" tables.
I need to recreate these reports in Power BI as most of our company's reports are located there and my supervisor wants the reports all in 1 place.
I was planning to create some data transformation tasks that would grab the necessary information from the JIRA database and saves it into our data warehouse database, where Power BI could query and display the report. However I can't find a data dictionary to indicate what the JIRA tables are for or the relationships between tables (I only want to copy what data I need and not transfer everything.). I'm trying to avoid having Power BI query the JIRA database directly.
I was wondering if there is a data dictionary or data model which details the JIRA and JIRA Service desk tables?
Sincerely,
Jason
is it less complicated to use an add-on that is already in charge of preparing the dataset to consume in Power BI such as Power BI connector
however if you want to extract directly from the database you can find the model of your instance in the path:
WEB-INF / classes / entitydefs / entitymodel.xml
There are different database schemes you can consult a pdf with the diagram of each type on this page
Thanks for the info. I have considered an add-on, but there is a cost / licensing fee associated with them. I have to prepare that I don't get authorization to purchase the add-on from my supervisor.
