Hi all!
We are working with Jira to describe problems and record measurements to solve the problems. Part of our workflow is, that the team mates responsible for diffenrent tasks have to be chosen by the reporter. Later on the team mates have to approve parts of the problem desciption or that they performed the measurement they were responsible for.
No comes the problem:
At the moment the reporter selects the needed team mates in the configured "people" field.
The approval is done by choosing "approved" or "not approved" in a drop down field. In the field name at the moment is only "person 1" or "person 2" statet. What I would like to configure is, that the team mates name is automatically added to the field name.
Thereby every team mate knows where to add his/her approval. And when exporting the issue it would be cleare who was responsible for this steps.
I hope you have some ideas to solve my problem.
Thanks in advance!
Diana
Hi @diana_pohle , it is not possible to modify the display name of a custom field in the way you're aiming to accomplish.
If I understand the problem correctly:
In order to accomplish this, I think there will need to be a number of changes to the issue workflow in Jira, the custom fields, and potentially some Jira Automation rules. Here's my thoughts:
This should capture those who have provided the approval in a new custom field, and the details of this custom field will be exported with the issue.
As this is a pretty significant change, I would strongly recommend testing this change in a sandbox or testing project before you apply this to your production environment.
Hi @Robert DaSilva ,
Thanks for your answer. I already thought that it wouldn't be as easy as I had imagined. ;-)
As we already have a clone of our project specifically for testing, I will try your suggestion there.
@diana_pohle Let me know how it goes! There may be some particulars you need to massage based on your specific instance and requirements.
