How do I create a subtask and auto-assign to a persion? I have tried the following ways, but none have worked.
- task1 / assignee:"David Smith"
- task2 assignee:"Dave Smith"
- task3 / assignee: "Dave Smith"
- task4 assignee: "Dave Smith"
could you please provide an example that I can test to confirm it works?
@Michael Lichtenstein Afaik the username, not the full-name, not the user-key is used in the template language.
So the example for a user with full-name "David Smith" and username davidsmith:
- task 1 / assignee:"davidsmith"
The full syntax is documented in the project's wiki here: https://bitbucket.org/hascode/jira-quick-subtasks/wiki/
Not sure I understand your question. Do you have some script creating sub-tasks ? If yes, what is the script language and what triggers the script ?
