×I want to remove the +2 on the Sprint Field but I it seemed that I cannot delete it. How could I possibly remove this?
Hoping for assistance.
Thank you!
Hello @Demi Hotahot
That indicates that the issue was in two previous sprints that were completed, but the issue itself was not completed in those sprints.
The only way to remove that information is to reopen the specified sprints, remove the issue from the sprints, and then re-close the sprints. That will change the end date of the sprint though.
Hi @Trudy Claspill ,
Thank you for your help!
The issue was not completed, maybe because I only clone it from the previous issue that was linked to the completed sprint. That's sad.
My only option now is to create new tickets and make sure there's no other completed sprints involve on the field.
Do you have better suggestions that I can do?
Thank you so much once again for the information!
Hello @Demi Hotahot
When you clone an issue you should have the option to choose whether or not the Sprint values are also cloned into the new issue.
