Remove active comment bar
Lauras Susa October 11, 2023
After Jira upgrade, there is a new comment bar, which stays always "on top". Its annoying, when you need to work on the go only with laptop monitor. It takes to much space on window.  Maybe its possible to revert to old version of comment field?
Jira Data Center 9.10
Thank you
Kseniia Trushnikova
November 15, 2023 edited
Hi @Lauras Susa,
You can remove a sticky comment footer by adding the dark feature com.atlassian.jira.commentStickyFooter.disabled. Please see more info in the Jira 9.8 release notes.
Hope it helps.
Abigail Huamanchumo
November 8, 2024
Is there anyway to keep the white theme and still remove the comment bar?
