Remove comments field on transition
Stefano Rosario Aruta
February 11, 2019 edited
this code it does not work:::::
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.fields.layout.field.FieldLayoutItemImpl.Builder
def c = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectsByName("comment");
c.setHidden(true);
//issue.getFieldById("Comment").setHidden(true);
Nadine Schütt
February 11, 2019
Hello @Stefano Rosario Aruta
I had the same issue just last week and solved it with ScriptRunner Behaviours.
Was easy to configure for specific transitions only rather than the whole Jira instance and works well.
Kevin Johnson
October 19, 2019
if you have the scripts can you please share cause i too wanna hide the comment field from a transition screen but i dont know how to do that or proper scripts to do that
Like 2 people like this
Nadine Schütt
October 21, 2019
Hello @Kevin Johnson
I am afraid I cannot provide a script since my proposed solution requires the Behaviours plugin. Do you have that and struggle setting up the comments field as hidden on a transition?
Here's a quick introduction:
  1. Open Behaviours in the Jira Admin Add-ons section and click Add Behaviour.
  2. Click the Fields link on the newly created behaviour.
  3. Choose the workflow you want to hide comments on as the Guide Workflow.
  4. Add Comment as a field and click on Shown to make it hidden.
  5. Add a condition and choose the required Workflow Action you want to hide the comment on.
I hope it works for you.
Like 7 people like this
Kevin Johnson
October 21, 2019
haha i know how it works and i can clearly state a step by step procedure to do it like you did
the problem is there is no proper way to code the scripts part thats the only issue
can you help in that ??
jamila.augustine
@Nadine Schütt : Thanks! Worked for me.
Shahriar
@Nadine Schütt , that feature of ScriptRunner is not available in JIRA Cloud. Is there any other way to hide the comment field in the transition screen?
Like 3 people like this
Nic Brough -Adaptavist-
February 11, 2019
You will need a script or automation to identify which ones you want rid of and destroy them.
can you make the script?
Przemysław Łyszkowicz April 27, 2023
Add to field that exist in screen on that transition: <script type="text/javascript">
if($('#issue-workflow-transition-submit').val() =='Transition name'){
$('div.comment-input').css('display', 'none');
</script>
Transition name replace with name of your transition.
Jason Child March 17, 2019 edited
Why not just edit the Announcement Banner (System > User Interface > Accouncement Banner) and inject some CSS styles to simply hide the comment input... simple, but effective and no custom fields need to be edited to inject javascript.
For one specific form:
<style type="text/css">
div#edit-issue-dialog div.form-body div.content div.field-group.comment-input {
display: none;
</style>
or... for all forms:
div.jira-dialog div.form-body div.content div.field-group.comment-input {
display: none;
</style>
A L November 23, 2019
it doesn't work jira core 8.4.2
Jason Child November 24, 2019
Hi A L. The above code was based on core 7.13, so they probably changed the style rules somewhat for the newer version. That said, the same technique of injecting global CSS styles via the announcement banner should still work.
You will have to use your browser development tools (firebug or chrome dev tools) to inspect the DOM and determine the appropriate selector for the comment field that you wish to hide.
Jeroen El Hahaoui
March 30, 2021
Small change for Jira 8.15 (server)
section#edit-issue-dialog div.form-body div.content div.field-group.comment-input {
display: none;
</style>
Grigory Salnikov
February 11, 2019
Hi @Stefano Rosario Aruta!
Please, check the similar question and the answers below:
Remove comments on transition
Hope it helps.
Like Grigory Salnikov likes this
Grigory Salnikov
February 11, 2019
Is not what you want?
i want remove the field comment on the screen when i do a transiction
Grigory Salnikov
February 11, 2019
I see. Check the similar question:
Hide "Comment" field on transition screens
it doesn't work
