Remove small attachments from emails?
Mark Wheeler
Is it possible to filter out all or small attachments from emails to Jira (e.g. anythign smaller than 3Kb).
Some people have 10-20 small icons in their email signatures and then if they reply to a Jira message on an issue, then the issue is flooded with 10-20 attachments. These attachments can confuse the issue and cause important information to be missed.
Can you stop small attachments being accepted via email?
Or is there a way to select multiple attachments at the same time to delete from an attachment?
Thanks Mark
Angélica Luz
May 4, 2020
Hello Mark,
When receiving requests or comments by email, currently, it's not possible to block images from signatures to be attached.
There are feature requests suggesting improvements for that:
Please, click on vote and watch to receive updates about the feature.
Angélica
Nicola Muratori December 23, 2021
i've successfully been able to do what you requested with automation
when
issue commented
then
delete attachment
WHEN
filename matches
tested for a while and it works.
