When I move an issue from "Done" and re-open it, the strike-through does not go away. How do configure JIRA to make that happen?
Hi
You need to add a post function to the transition from Done to Reopened which does that - you probably already have a transition for it, but just need to add the post function
The transition from done to reopen needs to CLEAR the resolution field. The strikethrough is there because a resolution is set.
