Request help with summarizing subtasks custom fields using a scripted field
Liz Craig May 8, 2023 edited
Request help with summarizing subtask(s) custom field “Result” at the parent issue level.  Using Jira Data Center 8.16 with Scriptrunner .  I am a novice with Scriptrunner and need help creating a scripted field that can summarize the information from the single select ‘Result’ field in the subtasks with options (Pass, Partial, Fail).
Need for the calculated field to summarize the subtasks based on the following:
  • All subtasks set to “Pass” == Pass
  • At least one subtask set to “Fail” == Fail
  • No subtasks set to Fail, but at least one (not all) set to Pass == Partial
  • All subtask “Null” == Null
Any guidance that can be provided is greatly appreciated.
SERVER
VERSION
8.16
