Required Fields
Diego Klubok
In a last generation project, can I modify, delete and / or rename the required fields? (see attached)
Joe Pitt
Required fields are set in the field configuration scheme for the issues in the project. When you say delete, I presume that is deleting it from the issues. If you do that you need to remove it as required from the field configuration. I've never tried to rename a field so it may change the name in the field configuration, but I presume it will still be required. What do you mean by modify?
Diego Klubok
How do I access the "field configuration scheme" in a next generation project?
Joe Pitt
I don't know. You said this was a last generation, which I took to mean what some call a classic project. I don't use next gen projects. There are too many limitations
Like Diego Klubok likes this
