Hey Guys,
So I have a required field below...Customer...however it's not showing up with the red * as a required field - see below....
As you can see no asterisk required. Is this a glitch or something? Also Customer Address below is a required field too...however no asterisk either?
Go through this and edit Field configuration https://support.atlassian.com/jira-cloud-administration/docs/specify-field-behavior/
I have made CUSTOMER required however it's not coming up as a required field...it's just coming up as a regular field...but as you can see in the screen shot above it's REQUIRED
Please go to Issues> Field configuration > ( Search for the Field configuration used in particular project) Click on Configure > click on the Required option beside the field ( as per requirement
As you can see its a required field...BUT it's not actually working as a required field, it's operating as an OPTIONAL field...there is no RED * next to it...
