Required custom field not showing on close issue prompt
James Dushay January 13, 2023
I Know I must be forgetting something here, but I can't seem to get these two fields to show up. They show up in the ticket details, but not in the resolve issue screen. I have
Ste Wright
Hi @James Dushay
Have you added the fields to the Resolve Screen? This Screen is configurable, like the main Issue Screen.
To do this, you'll need to be a Jira Admin:
  • Go to Settings > Issues
  • Select Screens from the left-hand menu
  • Locate the appropriate Resolve Issue Screen used in your Workflow
  • Add the fields that need to be populated
Note: If the Screen is used in multiple Workflows, and you don't want these Fields on every Resolve Issue Screen, then you need to create a new Screen specifically for this use case and replace it in the Workflow.
Let us know if this solves your query!
Ste
Last screenshot
