I have one field e.g. "Project Stage". which is present in Resolve Screen and I have configured it to be a required field.
But when I create an issue, I'm not able to create the issue as it asks that "Project Stage" is a required eventhough it is not part of this create screen.
please help.
Nayan
Nic Brough explained that very well on that answer - https://answers.atlassian.com/questions/195628/required-fields-issue-creation-screen-vs-required-fields-in-transition-screens-any-difference
In short - make the field optional and use workflow validators to make this field required on the resolve screen.
Thank you for the reply..
I had to install a plugin...and it worked..
Save your spot
