×you have different options. You can set the resolution via a transition screen, for example with the Close transition.
Or you set the resolution via a post function to a specified value.
Best regards and stay healthy
André
Did you edit your workflow? and if so did you add a resolution in your postfunction?
Or, and what I typically elect to do, add a Validator to require the resolution field to be set by the user transitioning the issue to Done. You will need to also add a screen to the transition with the resolution field. The reason I prefer this most of the time is that I like to be able to reflect on the different reasons an a issue is considered done, e.g. done, won’t do, cannot reproduce...
Yes I edited the workflow. Bud sorry I don't have experience with jira service desk, how do I add the post function or the screen in transition? Can you explain to me please?
This should help.
I am currently using Jira Service Desk, and do not have the options you indicate, as I have several projects created and for each created their own workflow, as can be seen in the attached images.
Hi @Magic Mike ,
I am facing with a similar situation here. The Resolution field is empty, so that the closed / resolved / unresolved issues are stuck "in progress", and cannot transition to "close". A legacy automation was created to transition an issue to "close" after 3 business days if the issue is "resolved".
For past issues associated with this workflow, how can I update the "post-function" or the value of "Resolution" in them?
Is it possible to bulk change the values in this "Resolution" field?
Thanks a lot!
Best,
Yichi
Consider editing the workflow and adding a temporary loop transition from done back into done or whatever you’re done status is. On that transition add a post function to set the resolution. Publish the workflow and then use bulk edit to transition all of the issues in the done status without resolution using this transition.
Hi @Jack Brickey ,
Thanks for your answer!
Please correct me if I am wrong, for future new issues, they will transit via the post-function - updating Resolution field and then be resolved? In this manner, I assume they will no longer displayed in the report as in progress?
Best regards,
Yichi
Assuming that your transitions to the Dan status from any other status have a post function to set the resolution then yes.
