hi guys,
i am new to jira. i am create a workflow like when the transition starts it will be closed and the Resolution filed set into Resolved. After the transition, the project gets the strike out but the Resolution field does not set into Resolved.For that i am adding the Post Function but it is not works and also i am trying through the screen it is also not works. so kindly provide me the solution if anyone knows.
Thanks in advance,
Karthik.
the following way you can configure postfunction on create issue transition
1.Go to Administration > Workflows
2.Click the link for the workflow in 'Steps' column
3.Click 'Open/New' link in the Step Name column
4.Click 'Create Issue' link in the Workflow browser (the inbound transition that arrives into the Open step)
5.Add a post-function, 'Update Issue Field', and set the Resolution field to desired Value (if necessary, create a draft so the workflow is editable)
Make sure the Post-function is the first step in the list
Setting the resolution on the issue create is a special case detailed on the Advanced Workflow Configuration:
If you need to set the Resolution field when creating an issue, add the Update Issue Field post function after the Creates the issue originally post function and after that, use the Store Issue post function. The Store Issue post function is useful for setting the Resolutionfield during issue creation.
However, keep the use of the Store Issue post function to a minimum, since this post function:
For more details, check the entire documentation at https://confluence.atlassian.com/display/JIRA/Advanced+workflow+configuration
Thank you Pedro,
I could not set the Resolution during the Create Issue transition. The Store Issue post function placed after the Update Issue Field - The Resolution of the issue will be set to Resolved does change the Resolution.
My use case is a workflow which has only the Closed status and the initial Create Issue transition. Used to document a fix that has taken place and needs to be recorded.
Tell where the problem you are facing or in which transition you kept your postfunction?
you can follow https://answers.atlassian.com/questions/200816/how-to-set-resolution-value-at-the-create-issue-step-in-on-demand-jira
where you can select your own Resolution value
Screenshots?
In the following link: https://confluence.atlassian.com/display/JIRA/Advanced+workflow+configuration#Advancedworkflowconfiguration-addtransitionvalidatorwd
i tried the special class paragraph, but it is not show the store issue
you check for Add link in the postfunction section, then you find Store Issue postfunction
hi prasad,
i tried the steps you are giving but can't click into the 'Steps' column
create draft and try, can you share screen shot of your workflow?
comman, i am asking what post function you used to set resolution on create issue transition?
which post function you configured?
can you share your post function code?
Learn more
