Restrict Access to commercialy sensitive pages in a project
oskfel_po January 13, 2025 edited
Is there a way of restricting access to certain pages within a project, for example, to admistrators only?
For example - forms, goals or summary pages?
It seems incredible that the only level of granularity is to turn the feature on or off for everyone who has access to the project.
Am I missing something?
Thanks in advance,
Simon
Tuncay Senturk
January 13, 2025
Hi @oskfel_po
Page level access restriction isn't a built-in feature for project-specific pages like forms, goals, or summary pages. Instead, the access is given at the project permission level.
You may want to check out ProForma Forms for Jira app.
Thanks for you fast reply @Tuncay Senturk
Im really surprised by that. Just by way of one example, we have Slack integration, and it would appear that anyone who has access to the project can add their channel - no admin access needed!
We have just started to use the releases feature and anyone with project access can create their own releases and add issues to any release! This could cause chaos if abused {shrugs}
May I kindly ask why you suggest Proforma Forms?
Tuncay Senturk
January 14, 2025
Hi @oskfel_po
You're absolutely right. Atlassian's focus is more on project- or issue-level permissions. Proforma allows you to define who (based on their roles, groups, or the issue type) can see or interact with specific forms. You can configure a form so that regular users might be able to see issues or forms but won’t be able to edit or submit them. I am not expert on Proforma but I know many companies started using it and relieved their painpoints.
oskfel_po January 14, 2025
@Tuncay Senturk - thanks again for your response.
We have managed the granularity for permissions on issue and field access using a combination of groups / roles together with behaviour and event listener scripts (ScriptRunner).
However, I'm not aware of how to apply these to urls (I assume its not possible) and that would thereby restrict certain users / roles accessing project features,
I appreciate your suggestion re: ProForma, but unless it could restrict features i.e. redirect a feature url, it won't move us forward in that direction.
I'm hoping sopmeone in the community has figured it out :-) and will post a solution {fingers crossed}
Like • Tuncay Senturk likes this
