I am new to JIRA on cloud and am trying to provide access to the business resources in the company to view JIRA backlog but do not want to give them access to edit things on JIRA. Can you help with the access management?
You should revoke the Edit Issues permission in the project permission scheme from the users, who do not have to edit issues. You can find more info about project permissions here:
https://confluence.atlassian.com/adminjiracloud/managing-project-permissions-776636362.html
1. Open your project (Projects -> View All Projects -> choose your project)
2. Click Project Settings
3. Click Permissions
4. Find the Edit Issues Permissions and have a look at the permissions. You must make sure that the users do not have this permission either directly or via a group or via a role.
Server or cloud? Basically you are simply dealing w/ permissions/security. You can define a group that is 'read only' and place those users into that group and then give that group Browse permissions.
read more here:
https://confluence.atlassian.com/jirasoftwarecloud/permissions-overview-764478244.html
or find the version for server if that is your situation.
In Project Permissions, grant access to Browse Projects, but deny access to Create, Edit, and Delete Issues.
Thanks for your answer. Do you have any descriptions on steps to do this. As I said I am new to JIRA and am trying to get my hands-on experience.
You are welcome! If my answer helped you, Kindly accept my answer. In this case other users with a similar question will be able to find this answer.
