I don't want to see the users in particular group in the suggestion list for assignee field
For eg : I am in a group called group A ..if someone is trying to assign issues to a user then my name won't appear there ..since I am in group A
So in conclusion I want to restrict group A from assigning issues
Hi @Aswathi D ,
Go to project settings --> Permission scheme --> Update Assign issues.
Assign issues grants Permission to assign issues to users. This permissions also allows autocompletion of users in the Assign Issue dropdown.
Please note: If the permission scheme is shared with other projects, changes will be applied to all shared projects. In this case, you need to create a copy of permission scheme, modify the copied scheme and map the copied scheme to required project.
https://confluence.atlassian.com/adminjiraserver/managing-project-permissions-938847145.html
No
