Restrict changes to the priority field based on project role
Timo Scherer January 8, 2025
Hi everyone,
is there a way to control who is able to alter the priority of a given issue? Ideally, I would be able to define which role is allowed to alter the priority state, thereby preventing everyone else from screwing up our priorization scheme.
Is there an option I have not found yet or would this function need to be implemented?
Timo
Fazila Ashraf
January 8, 2025
Hi @Timo Scherer
Welcome to community!
It is not possible to control who can perform edit operation on the field priority.
The general way of getting around this problem will be to not have 'Priority' field in the edit screen. But instead have a self loop transition (say 'Change priority') in the workflow that is restricted only to a given project role. In that transition screen, you can have the field priority.
Hope this helps!
That sounds promising. I'll look into it. Thanks a lot.
Trudy Claspill
January 8, 2025
Note that the Transition Screen functionality will be available only if you are working with a Company Managed project. It will not be available if you are working with a Team Managed project.
Amulya Sankara January 9, 2025
Hi @Trudy Claspill
I have a team managed project and I'd like to set up controls on which users can change the priority of the issues. As you mentioned, I could not find the transition screen functionality.
Is there a way to set up such a restriction in team managed projects?
Trudy Claspill
January 9, 2025
Hello Amulya,
Unfortunately, no, there is no native method in Team Managed projects for restricting access to edit the Priority field.
And I am not aware of any third party app that would provide this, specifically for Team Managed projects.
Like Amulya Sankara likes this
Amulya Sankara January 10, 2025
Okay, noted. Thankyou
Lucas Knorr
January 8, 2025
Hi @Timo Scherer
there are two solutions for your requirement.
1. You can remove the priority from the screen that is linked to the edit action. This prevents the priority field from being changed for everyone. Then you implement an additional transition with a transition screen on which you place the priority field. You can use a condition to restrict the transition so that it is only available to certain users.
2. You license a plugin like Scriptrunner and utilize Behaviours.  (https://docs.adaptavist.com/sr4jc/latest/features/behaviours/behaviours-supported-fields-and-products).
Trudy Claspill
January 8, 2025
Adding to this....
Regarding option 1, Transition Screens are available only in Workflows used for Company Managed projects. If you are working with a Team Managed project, this option will not be available.
