Restrict priority indicators on a per project basis
Geert Truyen
JIRA onDemand version
Can the use of priority indicators that can be used be restricted to a subset of all existing indicators on a project by project basis?
Suppose 10 priority indicators exist for different purposes and for a particular project only 4 are presented and available to be used for that particular project.
Thanks for your advice.
Christian Czaia [Decadis AG]
August 30, 2012
Hi Geert,
if you're talking about the priority system field then the answer is NO. This issue has been around for AGES:
Check these out:
http://old.nabble.com/-JIRA-user--Priorities-per-Project-td8298220.html
https://jira.atlassian.com/browse/JRA-980
You should vote for that one:
https://jira.atlassian.com/browse/JRA-3821
Cheers Christian
Geert Truyen
Thank you Christian.
I definitely voted on that one !
August 30, 2012
It's a joke. More than 8 years... :-)
Geert Truyen
Unbelievable.
These dudes make good software so what's preventing them to integrate this important feature?
Contact _Develocenter_ September 7, 2016
Hi Gaert,
It's still!! not available in JIRA out of the box. For now you can try Extended Schemes for JIRA which allows you to manage (hide and show for Projects/Issue Types) for Priorities, Resolutions and Link Types. Unfortunately, from the technical reasons it's only available on server now.
