×Hello,
we work with several "Developer Tools" (different BitBucket installations) on our Jira Data Center instance. If a project creates a branch they get options to choose from.
Now a single project only works with one BitBucket and my question is, is there a way to restrict the visibility of the "Developer Tools" in a project?
Desired result would be, only get the correct BitBucket as an option when creating a branch.
Thanks and best regards
are you trying to integrate a single Jira DC with multiple Bitbucket/other developer tools? if yes then I think it would be possible with a custom add-on. I too had the same requirement but failed to get the result so we are looking for custom add-ons.
Thank you @Vedant Kulkarni_Trundl Yes, that is the case. A single Jira DC instance with multiple BitBuckets.
Custom add-on means, self developed or is there any marketplace solution I am missing?
