Restrict transition based on field Fix Version
Mircea Craciun
I am trying to configure my team managed project to restrict a transition if a field has no value. Sadly, the field I am looking for (Fix Version) is not in the dropdown. Where/how can I configure it to show up in there?
Thank you.
Trudy Claspill
August 21, 2024
Hello @Mircea Craciun
The short answer is you cannot do that.
That rule within a Team Managed project workflow supports only the fields that you see in the list. You cannot configure which fields the rule can support.
There is a change request asking for that field to be supported. You can add your vote to that.
https://jira.atlassian.com/browse/JSWCLOUD-21430
Mircea Craciun
thank you
FREE
