I am looking to implement a rule where users can log work hours only within 30 days of a ticket being closed. After the 30-day window, logging hours should no longer be permitted.
Currently, I have the JMWE add-on and am exploring if there’s a way to accommodate this request using its capabilities.
I tried adding the following property:
jira.permission.work.denied
However, this property alone does not fulfill the requirement of restricting work log entries based on the issue closure date.
Has anyone implemented a similar solution or could provide guidance on how to achieve this using JMWE or any other workaround?
Thanks in advance for your help!
Hey @Srinivas Salver,
Depending on your current rule consumption, your scenario should be doable using a dedicated status, e.g. 'Closed', and a scheduled automation rule, that
You should also be able to add a condition to the transition to 'Closed' so that only the automation user can run this transition.
Thorsten
@Thorsten Letschert _Decadis AG_ thanks for your input how does this automation rule validates only within 30 days of a ticket being closed users should have the ability to log the hours?
and after 30 days they shouldn't have the ability to log the hours which is in Done status.
@Thorsten Letschert _Decadis AG_ Thanks for the update.
btw how does the automation rule validates? where users can log work hours only within 30 days of a ticket being closed.
Meaning users should have the ability to log the hours once the ticket is closed and after 30 days they should not have the ability to log hours.
Hey @Sam Lin
Since you can't validate the actual work logging, this approach aims to transition the issue to a status where work logging isn't allowed anymore after the 30-day threshold.
