Restricted View on certain Issue type
Mimi Peters
Hi there,
I would like to ask how to proceed with two scenarios in a Company managed project:
1. Certain Issue types only show to Approved Viewer when creating a new issue
2. Certain Issue types will auto-move to Issue Security Scheme once it's created
Any suggestoins?
Mark Segall
April 11, 2023
Hi @Mimi Peters
If I'm understanding correctly, you want to establish permissions on who can create a specific issue type?  If so, this is not possible.  Ability to create issues is set at the project level with the create issues permission.  So, if you wish to make it so only certain users/groups can create a specific issue type, that issue type would need to exist in isolation on another project.
You can accomplish this easily with Jira automation:
  • TRIGGER: Issue Created
  • CONDITION: Issue Type is one of (your desired issue types)
  • ACTION: Edit Issue (Security Level)
    • Your desired security level
Mimi Peters
I see thanks Mark, so it has to be done in Automation? No other ways?
Mark Segall
April 11, 2023
Jira automation would be the best course.  You may be able to achieve it with a workflow post function, but automation gives you more flexibility if you want conditions or other actions to occur.
Mimi Peters
So the workflow post function is not possible right after "Created" as we experiment it works from Created to "In Process" but not able to do it right after the ticket is created.
Mark Segall
April 12, 2023
I recommend simply leveraging the Jira Automation rule I proposed above.  It's a light weight rule on a single project so it should not impact automation quotas.
Like Mimi Peters likes this
