How do I restrict creation of components by project members?
Any user with ADministrer project permission can create components.
Please check this community post on how to fix that:
Restrict ability to create components to only certain users
by checking project > project settings > permission > Administer projects. That permission should only be for the project admin.
REgards
Aaron
Hey Aaron, thanks for your response.
I am trying to restrict creation of component by project members and I have changed the Administer Project to Single User (myself). I am still able to create components while creating a new issue while logged in from Project Member account.
Hi and Welcome!
This project member most likely also has the Administer Project permissions via their project roles (see project roles and permissions):
https://support.atlassian.com/jira-cloud-administration/docs/manage-project-roles/
https://support.atlassian.com/jira-work-management/docs/create-project-components/
Hope this helps!
Hey Jeroen, thanks for your response.
From the documentation:
Components are sub-sections of a project. They group issues within a project into smaller parts. You can set a default assignee for a component, which will override the project's default assignee for issues with that component.
You must have the project-specific Administer projects permission or the Jira administrator global permission to:
Add components — create a new component against which issues can be aligned
Select a default assignee — choose who is automatically assigned to issues with a particular component
Edit — change the details of a component
Delete — remove a component
So, you might be doing something wrong still with the permissions.
Unless you mean that you want to restrict that members can add a component to a ticket?
Hey Jeroen,
Thank you for the information. I was able to achieve the desired outcome using the articles and information shared.
