Sign up Log in
Restricting edit to multiple groups
Omar Bennani
I've been following this guidance:
How to restrict editing of an issue in a specific status | Jira | Atlassian Documentation
but I'm running into a hitch. How do I list multiple groups or roles to have edit access for a specific status. I've tried both groups or roles and using a comma separator like:
but that appears not to work. What's the right delimiter? It does look like it works when I only provide one value.
Trudy Claspill
July 25, 2024
Hello @Omar Bennani
I believe you need to define a property for each value, adding a numeric suffix to each property key.
jira.permission.edit.projectrole.1 = 10076
jira.permission.edit.projectrole.2 = 10029
There is an example of this, the way it worked in Jira Server/Data Center, here:
https://www.j-tricks.com/tutorials/permissions-based-on-workflow-status
Omar Bennani
This worked like a dream! As a tip for someone else finding this note. 1. don't use generic suffixes like .1. It'll happily take a name like .product which will help tremendously when you're doing a group mapping which must use the extremely long ID references. Which, as a second tip, use the API method to get group ID like https://COMPANYNAME.atlassian.net/rest/api/3/group/member?groupname=atlassian-addons-admin
